nuubje006
Oct 18, 2019Star
Nighthawk RMX570 - Wifi is working but dashboard says it is disabled
Hello, The sahboard says my wifi 2.4 and 5 GHz are disabled. Even though I do get wifi. The wifi connection is also pretty bad. Not sure what is causing this as it seems to be perfect start of the...
Netduma-Fraser
Oct 23, 2019NetDuma Partner
It may be going offline as I assume it goes into standby until you start a print job. Is there anyway you can turn it off standby or see if when you turn it off and on again if it comes online properly. Then check if you can wirelessly print, if so then may be something to do with standby.
nuubje006
Oct 23, 2019Star
It used to work wireless, but even that is not working. Never tried it before I had the nighthawk with my pc. But I will try connecting it with an ethernet cable and see if I can somehow get it to work wireless later if I start over again.
Thanks for the help!
