nuubje006
Oct 18, 2019Star
Nighthawk RMX570 - Wifi is working but dashboard says it is disabled
Hello, The sahboard says my wifi 2.4 and 5 GHz are disabled. Even though I do get wifi. The wifi connection is also pretty bad. Not sure what is causing this as it seems to be perfect start of the...
nuubje006
Oct 23, 2019Star
Will I only have 1 thing from HP so I think it is the printer. But it seems to keep going to offline, I'm going to restart and try it again. I can't see the IP of the printer as it doesn't have a screen. But I was able to find an IP of the HP item in my router and I could ping it. But still it stays offline. Dunno ;p The one thing in IT that is rocket sience for me is networking.
Guess I need to start over and disable all devices to start with and add them one by one.
Oct 23, 2019Guru - Experienced User
What is the model of the printer?
nuubje006 wrote:Will I only have 1 thing from HP so I think it is the printer. But it seems to keep going to offline, I'm going to restart and try it again. I can't see the IP of the printer as it doesn't have a screen. But I was able to find an IP of the HP item in my router and I could ping it. But still it stays offline. Dunno ;p The one thing in IT that is rocket sience for me is networking.
