Wyzfar's avatar
Wyzfar
nighthawk speed test
Hello so whenever doing a speed test on the nighthawk xr500 while doing a network setup it says bandwidth test failed and my download Speeds look about normal but it sets my upload at 1000 mbps upload which I feel is way off (to high)
  • FURRYe38's avatar
    What FW is currently loaded?
    What ISP speeds do you pay for UP and Down?
    • Netduma_Jack's avatar
      Netduma_Jack
      NetDuma Partner
      To add to this - I believe Speedtest, who NETGEAR use to run this test, have had a few server problems lately which has affected this. Perhaps try running it again now and see if it's working (you will need to factory reset to reinitiate this test).
      Don't worry if you would prefer not to, manually entering in your speeds is more than sufficient.
      • Wyzfar's avatar
        Wyzfar
        I just reset my router last. Ugly had anything server related changed within the last 24 hours? - and whenever I dedicate speeds like let’s say 200 download to my ps4 it’s not consistent
