Webbo
Dec 12, 2022Aspirant
nighthawk XR1000 geo filter not working!!!!
I picked a netgear XR1000 up 3 days ago and the geo filter has only worked once. I'm from the UK and wanted to play on American servers and it won't let me move servers again it's like the geo filter isn't even working. It just pings at the usual low pings so I know it isn't even on the American servers now. I'm close to just getting a refund after paying top money for this and going back to my asus router. The geo filter when it worked the once pinged at 100+ from start so I knew it worked but now it doesn't even act like it's on. I've tried back dating the firmware and turning qos on and off, refreshing the clause multiple times, hard reset and multiple reboots.
Take a look at the bottom of this guide: http://support.netduma.com/en/support/solutions/articles/16000077072-dumaos-optimal-settings-guide-geo-filter
it will let you know how to allow your friends so that you can connect to them when you are using filtering mode. Could you provide a screenshot of the Geo-Filter when you see the server outside your radius please? Then I can best advise.
What browser are you using?
Please take a screen capture of what your seeing.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
GeoFilter is working for me however I'm in the USA:
- WebboAspirantHey man, is there anything I can discuss this further with you on like discord? I'm currently not at home so I won't be available today.
- Netduma-FraserNetDuma PartnerTry this:
Quit the application/game/client completely
Remove device from the Geo-Filter
Give PC PlayStation Device Type in the Device Manager (if on PC)
Resync from the Geo-Filter Map menu
Re-add the device to the Geo-Filter with the manual option
Set up the Geo-Filter how you like (Ping Assist has to be set to 0 which it sounds like yours probably isn't which is why you're still getting low pings)
Wait 2 minutes
Boot up application/game/client
Then see if it works better.
