Xavy
May 01, 2024Aspirant
Nighthawk XR1000 not connecting to the Internet
So I'm trying to use this router that I have, I honestly didn't buy it I have no clue how it got there but before I go to buy another one I'm trying to get this XR1000 one to work. Me and my family have Frontier Fiber Internet, we don't have a modem just one of the boxes in the wall that I believe is called an ONT box. Before trying this XR1000 we have been using an eero 6 pro which worked just fine with the same cable. When trying to setup the XR1000, I just plugged the Ethernet cable that was originally plugged into the eero 6 pro and plugged it into the XR1000 and the Internet refuses to "connect" or turn on or whatever. The Internet led symbol does not even turn amber it just stays off so maybe I'm doing something wrong? First time using and trying a Nighthawk router so any help would be great thank you 🙂
What Firmware version is currently loaded on the XR router?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.- XavyAspirant
- XavyAspirantAlso sorry yes I did try and restart everything and still no cigar :c
- Netduma-FraserNetDuma PartnerYou don't need internet access to access the router interface - what do you see when putting http://192.168.1.1 in your web browser?
- Netduma-FraserNetDuma PartnerHave you accessed the interface and completed the Setup Wizard? You will need to do this before you're able to get internet.
- XavyAspirantNo I have not because it won't let me connect to the Netgear Internet in general which means I cannot use the app to do anything 😞
