Mikemike2177's avatar
Mikemike2177
Nighthawk XR500 continues to randomly drop connections
So i have been searching and having this issue for days now both my wired and WiFi devices will randomly lose their connection to the XR500 i have already tested to make sure the problem is isolated to the XR500 which is discouraging to see many people with same issue on a high end router with a high price tag.... the issue happens at any workload level weather it be a single device in use or 10 my ISP provides speeds of 400 dn / 20 up please help me resolve this issue as i will be returning to a work from hone setup and this will directly affect that... thank you!
  • Sorry to hear you're having trouble!
    Do these drops occur in any kind of pattern? At a particular time perhaps?
    Are you able to access the XRs interface when this happens?
    If not, do you need to manually reboot the XR or will it come back up on its own?
    • Mikemike2177's avatar
      Mikemike2177
      So it happens all day and it’s more of a hiccup but enough to knocks my devices off line and then connect back up almost instantly but it def interrupts all activity connected to a spectrum provided modem
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Go to Settings > Monitoring > Connection Status - what does DHCP obtained/expires say?
  • plemans's avatar
    What firmware are you on?
    What modem/gateway is it connected to?
