philter71
Mar 22, 2023Follower
Nighthawk XR500 create network folder greyed out
Trying to add a Seagate 6T Expansion desktop drive to router to create a network drive but even though all USB settings are on and all access methods are turned on the "create network folder" button and the "Safely Remove USB Device" button are both greyed out and hovering over them turns mouse pointer to a red circle with a line through it. Any help will be greatly appreciated.
Be sure the router is seeing the drive when it's connected.
What format is the drive using? I believe NTFS or exFAT are supported...
- Netduma-FraserNetDuma PartnerCould you provide a screenshot of the page please?
