Martin466's avatar
Martin466
Nighthawk xr500 cutting out
Hi everyone. So, long story short my router was doing a great job until recently. It now randomly just cuts out and I constantly disconnect from games or have huge lag spikes. I have disconnected it and my modem works fine so it’s not that. So it must be the router, idk if someone has hacked it or what. (Not good with technology haha) when I reset the router it works well, but then it will randomly disconnect again. I don’t know what to do.
  • FURRYe38's avatar
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Does it happen to all devices or just the gaming device? Does it occur across all games or one in particular? If you disable the Geo-Filter while playing does it still occur?
