Subarumatt93
Nov 14, 2020Aspirant
Nighthawk XR500 dropping connections constantly after only 3 days
So I bought the Netgear Nighthawk XR500 after my 5 year old R7000 was broken during a domestic situation (it was still running strong) so I was given money to replace it. I ended up buying the XR500 and loved the dumaOS and everything for the 3 days it worked as great if not better than my R7000(AC1900) (had to move because domestic dispute was dad's girlfriend attacking me, and he's staying with her) so I can't use the same connection to compare. On the 4th day it started dropping both 5g and 2g connections randomly, and then on the 5th day it was dropping connections every 5 minutes. I saw the 5G band wasn't sending out any internet (maybe .25 mbs when I averaged 240) so I disabled the autoconnect for which band a device gets assigned to and changed everything to 2G. Worked fine for about 12 hours and then same thing, no internet. For the past week I've had to revert to the router the internet company gave me (4.5x slower) and it hasn't dropped at all. I'm a college student graduating in May and cannot afford all of these disconnections. I haven't done a factory reset or anything since changing back to the old router and I submitted a ticket as well, but figured I'd ask the community. I've also noticed amazon only sells like new returns of this router so I'm assuming it's a known problem? Any help is appreciated. I have downloaded a wifi analyzer app, but have not attempted using it yet since I wanted to get advice from those who know more than me. Looking for all recommendations of things to try/if it's been proven as a problem router so I can return it (bought new directly from netgear)/known fixes/or better routers for same price. My overall preference would be to keep this router and have it work correctly, but it is what it is. I also know of the future dumaOS 3.0 update, and that may be the fix all of everything, but waiting for an unannounced/unproven firmware update isn't my answer. Thanks in advance for any help!
- Netduma-FraserNetDuma PartnerSorry to hear about your home situation as well as the issues you're having. Yes there is an ongoing issue which sounds like what you have. Please try these suggestions:
Set a static/reserved IP for the XR in the ISP modem/router
Set static/reserved IPs for your devices in the XR LAN Settings
Do use the WiFi analyzer to find the least congested channels and change to those
Do wired devices disconnect also?- Subarumatt93AspirantI don't have a traditional modem as it's a fiber connection that goes directly into a powered plug and into my router. All my devices are wireless and as far as I can tell all drop connection for just a split second, but when it comes to gaming (selling point of the router) that's not really acceptable. I'll post results of my wifi anyalyzation. Mine is the one that starts with Corey's
- Netduma-FraserNetDuma PartnerOkay so the 5GHz is fine. Is it possible for you to connect via ethernet when gaming? If you have to play via WiFi then 2.4GHz would be better as it is more stable. Can you provide a screenshot for 2.4GHz as well?
