pullsouthair101's avatar
Apr 10, 2020
Nighthawk XR500 slow output
My new nighthawk XR500 router only puts out about 100Mbps wifi and LAN.
When i hook my PC directly to my modem i get downloads speed at 505Mbps
When i hooked up the router and did the setup router saw 508Mbps
But when i have my PC connected to the router i only get 100Mbps downloads (lan and wifi)
Fimware:
V2.3.2.56
new Cat8 cables
QoS on or off makes no differance bit slower with it on
Have connected to different LAN ports
Router is brand new so i don't think something is wrong with it just some setting i know nothing about can ony one hlep?
  • Have you changed any QoS settings? If you disable QoS completely from the Anti-Bufferbloat option menu does that help?
    • pullsouthair101's avatar
      pullsouthair101
      I had to do a second factory reset for some reason (on a brand new unit) and now it is working fine.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Okay well keep us updated, hopefully it doesn't happen again.
