Sand323
Oct 30, 2023Guide
Nighthawk XR500 slow upload
Hi guys, spectrum around my area just got upgraded to 1 gig and since the upgrade my router just went to crap. My download got better but my upload won’t exceed pass 2 can anyone help??
I’ve already factory reset my router twice and spectrum already came down twice and there connection is solid.
Glad they got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
couple guides worth going through.
Re: Ultimate Speed Guide for XR500 and XR700 - NETGEAR Communities
Optimal DumaOS Settings - DumaOS on NETGEAR Nighthawk Support - Netduma Forum
- Netduma-FraserNetDuma PartnerHave you entered your new/expected speeds in Bandwidth Settings? Where are you testing the speeds exactly?
- Sand323GuideYes, I put the new speeds into the bandwidth and have been testing the speeds through the router log in for the dumaOS
- Netduma-FraserNetDuma PartnerTest on speedtest.net, what speeds do you get?
