kell90
May 06, 2022Aspirant
Nighthawk XR500 traffic prioritization feature not loading after switching to Starlink
Model: XR500 Firmware: V2.3.2.134 OS: Windows 11 ----------------------------------- Hello, I recently just switched ISPs (Xplornet to Starlink) and I believe I have everything set up mostly cor...
Netduma-Fraser
May 06, 2022NetDuma Partner
Your ISP wouldn't dictate whether the feature loads or not, I suspect that is a coincidence. Reboot the router from the interface, wait 2 minutes then try accessing and see if it loads correctly please.
kell90
May 07, 2022Aspirant
Did not solve the problem, unfortunately. I've tried various restarts and refreshes, yet this problem only persists when connected to Starlink.
