kell90
May 06, 2022Aspirant
Nighthawk XR500 traffic prioritization feature not loading after switching to Starlink
Model: XR500 Firmware: V2.3.2.134 OS: Windows 11 ----------------------------------- Hello, I recently just switched ISPs (Xplornet to Starlink) and I believe I have everything set up mostly cor...
kell90
May 09, 2022Aspirant
Netduma-Liam Netduma-Fraser
It appears reverting to firmware version 2.3.2.114 has returned the Traffic Prioritization menu. The next step is to see if the dropout/connectivity issues are resolved, which agent47isn1 seems to also have experienced.
If everything works well on this firmware version, is there any reason to do what Netduma-Liam suggested (revert to old firmware, factory reset, then return to the newest firmware) other than for curiosity?
Thanks for the help so far by the way.
agent47isn1
May 09, 2022Guide
Yea I have the traffic prioritization menu is working as well on my firmware. I haven't updated to 2.3.2.134 yet only because there's talks of other issues going on that are unrelated to what happened to me so figured I'd wait until the next one. And no problem figured I'd share what worked for me.
