AL221
Nov 28, 2020Aspirant
Nighthawk XR500
I just got the new Xbox series X, and my console was having trouble downloading content. I am using a wired connection that’s connecting to 1st wired port on the router. When I went to the VLAN/Bridge settings under advanced settings of the DUMAOS settings, I enabled the VLAN/Bridge group and under bridge group, I selected the first wired port, and applied the settings, and somehow my Content started downloading. Is there a reason why this worked. It is safe?
- Netduma-FraserNetDuma PartnerDo you know if you actually require VLAN? I would be very surprised if you didn't and that cause it to work. What is your exact physical setup?
- AL221AspirantThanks for replying! I honestly have no idea if I require it. Honestly don’t even know what that means, lol, I’m not very good with this router stuff. By my physical setup do you mean how my router is setup?
- Netduma-FraserNetDuma PartnerOkay so you probably don't need it then, no idea how that worked. Yes how is the XR connected to the internet e.g. through an ONT, ISP modem/router etc and how your devices are connected.
