ATOMINSF's avatar
Dec 03, 2020
No Access Control on XR1000
The R7000 had something call Access Control.  The XR1000 does not.  If someone were to get access to a ethernet cable they will be able to access your network.  Example, you have an IP security camera hooked up outside your house, anyone could have access to your network.  The R7000 Access Control had a button that blocked any new device from getting onto the network wired or wireless.  The XR1000 uses an outside computer for the OS and it doesn't have this feature.
DUMAS OS has a block feature.  Once a device gets in, you can block it, but it doesn't stop that device from getting back in.  I have had the same device on my network, after blocking it 5 times.  The other 5 times still shows blocked while the device is still working on a 6th connection.  I did a factory reset, but when it happens again, I will post a photo.
