Amg1108's avatar
Amg1108
Nord VPN on XR500
Hello, I’m looking to use Nord VPN with my Nighthawk XR500. I keep seeing I need the OpenVPN configuration but don’t know where/how to find it. Can anyone walk through how to set this up?
  • You will need to login to your NordVPN account on their website and find the config files, likely in a download section. Then paste the contents of the file into the Advanced Setup on Hybrid VPN
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        What are the options they have given you? You can take a screenshot if it would be easier
