MatthewH123's avatar
MatthewH123
Follower
Jan 05, 2020
OpenVPN configuration
Hi, recently purchased an XR500, and was trying to set up the OpenVPN server it is able to connect successfully but I am unable to access certain local resources (local web pages running on a local machine). Was wondering if this is an issue with the router, the server itself, or the OpenVPN configurations (either client or server). Thanks
  • I'm assuming you have selected the option for local network on the service page? Have you tried with both TAP/TUN and different ports? You may have more success by starting a ticket directly with Netgear http://support.netgear.com/
      • Flix2013's avatar
        Flix2013
        what i have don so far i Setup a Dynamic DNS With  no ip Then  I activated the VPN Setting an Downloaden the certifikation file an instaled it on Open VPN Client connect. After i Saw your Post i changed the Port to use and renewed the certification file. Tried do Connection again it says im conected but i still cant Connect to the Server just router. Sorry for Wasting your time but thx for the Help👍
        I cant Change between tun tap but between tcp and udp
