usermac
Aug 17, 2018Luminary
Please FIX GEO FILTERING MODE PUBG :(
PUBG and the filtering mode is simply not working when matchmaking. I can not connect to any local server.
Its used to be when matchmaking it would skip putting me in servers out of my selected area and now it will put my in servers way out of region. The lagg is terrible in this game as it is.
I know servers are different now I have not seen an Amazonaws server for weeks so maybe they scrapped useing them.
The thing is I test the filter on fortnight and it works the filtering system on this router is amazing. So it is just PUBG and that is my game I play and love at the moment and really want to know how Netduma is getting on with this.
I just want to be able to connect to London server not South of Germany or at worse USA
- Netduma_JackNetDuma PartnerHi Mac - thank you for letting us know about this. It’s very likely that Blue Hole have changed their server setup given their whole ‘Fix PUBG’ campaign.
 We will test this ASAP and push a cloud update out which should automatically correct the locations.
 In the meantime, I recommend you switch to spectating mode and enable auto-ping. Then while you are in the lobby with the other 99 players, you can back out if the ping is too high.
 Thanks again for bringing this to our attention.- usermacLuminaryThanks for the advice I will use the spector for now. - usermacLuminaryI dont want to moan and that but I do feel verry little is being done in order to get this GEO Filter working. I have been using the spectator for about a month and am simply fed up with having to leave games due to high ping. One in in ten matchces I will be lucky to get a london or france server instead I am put in high ping server and have to repeat process. Is Netduma any closer in getting the GEO FILTERING working on PUBG A cloud update is needed ASAP or some information on Netdum's progress in how they are getting on with tackling the issue's getting the Geo Filter working. Host Type Peer
 ID 1b5808d3f5bac5ca
 Domain Name 58cabad3.setaptr.net
