Netduma-Fraser
Dec 17, 2019NetDuma Partner
Please read if you're experiencing DumaOS not loading/login interface issues
We have received multiple reports about these issues. I have reported this to our team as this seems to be affecting a few people today, please follow these instructions provided as a workaround whil...
Starworshipper
Dec 17, 2019Initiate
Same issue, just chiming in.
Factory reset DID NOT work.
Downgrading the firmware DID work.
Time to spend a good hour or two resetting my configuration. Feelsbadman.
- Netduma-FraserDec 17, 2019NetDuma Partner*Update* We have identified the issue and we are working on an immediate fix. We will update this post with further information when it is safe to reupgrade back to .56. Thank you for your patience.
- Netduma-FraserDec 17, 2019NetDuma PartnerPlease see here for the fix: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/Fix-for-quot-DumaOS-not-loaded-yet-quot-XR500-users-only/m-p/1838160#M15459
- LevelUpLiam24Dec 18, 2019Apprentice
Had the same problem this morning, I can confirm the solution.
Downgrading the firmware to V2.3.2.32 resolved the issue.
Remember to deactivate router auto firmware update if it's enabled.Awaiting a fix for this issue. Thank you!
- Netduma-FraserDec 18, 2019NetDuma PartnerPlease see the post above yours for the link to the fix. Essentially if you re-upgrade back to .56 it should now work fine for you.
Worked like a charm, everything is running correctly.
Thanks so much for calling that out can't believe I missed it.And thanks to the devs for addressing the issue!
Hope everyone at Duma has an awesome holiday!
