KAustralia's avatar
KAustralia
Follower
Oct 09, 2023
Pro Gaming XR1000 - Can't connect to NBN home - says no internet connection
Hi. We are not getting internet to the router when we connect to the NBN home box. Our ISP said it should be compatible, We have tried Netgear support who after 2 hours trying to help told us the unit was faulty. We returned it for a replacement and have the same issue. It says no internet connection on the app. No issues with our internet to the house. Any suggestions please?
  • FURRYe38's avatar
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    Be sure there are no specific ISP configurations needed. Something to ask the ISP about.
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
  • Do you know if you require PPPoE or VLAN or DHCP identifiers at all for a connection?
