jebrown1979's avatar
Jun 22, 2019
ps4 randomly disconnects on xr500
the ethernet disconnected twice yesterday causing my ps4 to lose online status untill i rebooted. also my samsubg galaxy tab 3 can only use 20 mins of wifi before it disconnects and have to be reconnected very frustrating when your watching something also lag is still evident in this router that i paid £250 for much much more lag than my r7000. i dont know if i have set it up right or if something needs changing. bufferbloat is set to 70% on both. i have a smart home where everything connects to wifi but nomore than 3 or 4 devices used at once. say if my girlfriend is watching tv downstairs the tv is connected so is the sky box. then i wil be upstairs using pc and ps4. because other things are connected but not used they will send and recieve some data so i dont if bufferbloat needs to be always on or just when high traffic is detected. i live in hull i have my own isp 400mb down and 35mbup i am really at my wits end so any advice is really really appreciated.
  • FURRYe38's avatar
    Ensure your using good quality LAN cables. CAT6 is recommended.
    Set a IP address reservation for the PS4 and any other devices connected ON the router.
    Possible you have BB set to low, try 80 or 90% and see if this still continues to happen.
    • jebrown1979's avatar
      jebrown1979
      Guide
      the firmware is the latest V2.3.2.40 A7legit. its my isp white ONT box not a modem that my router connects to i send you a pic if you want.
      i tried BB 85% it worked for a while then 2 disconnects but gameplay wise it was alot better. going to try BB at 90%
      i have an AFX gaming cat6 cable from my white ONT box to my router and the same cable from my router to my ps4 they cost £20 each so i hope they are good cables lol.
        jebrown1979
        Guide
        oh and when it does disconnect it sometimes comes back as 100MB connection so i have to unplug then plug back in to get the white light on my router. but the strange thing is my pc when powered down i mean totally off shut down still shows a red light on the router but when ps4 is shut down there is no light which leads me to believe there is something wrong somewhere
