dark_tribute381
Sep 02, 2020Aspirant
PSN/WiZ LAN Issues
I have recently upgrade from ADSL2 to NBN in Australia, Since the upgrade which moved me to a VLAN/Bridge setup as "VLAN ID 2", "Priority 0" which then connects the WAN Socket and that goes to a netcomm NDD-0300.
Since the Shift to the NBN service, I have begun having NAT issues during use on the Playstation Network as I have 2x PS4 Console in the house.
During use of the Chat System or the In-game parties the connection between the two consoles is extremely poor and cannot connect properly causing audio distortion or disconnections, these issues only occur with the other console on the LAN all external connections function as normal our WiZ Smart lights are also having connection issues and take multiple attempts for our Google Home to connect to them.
I have switched the XR500 with an old N600 and in which I set up in a near-identical manner in which it does not experiance any problems that I have experienced with the XR500.
Please note I have done factory resets with both Routers and only the XR500 experienced issues after the shift to the NBN.
Any assistance is appreciated.
XR500 Firmware V2.3.2.56
Ben
- Netduma-FraserNetDuma PartnerIn WAN Settings changed NAT to Open instead of Secure, does that resolve the issue?
- dark_tribute381Aspirant
I had previously changed this to open, there was no improvements on there network stability. It seems all devices that authenticate over the internet that are connecting locally to one another are affected.
TVs, Soundbars, and Printers are all functioning as normal only Google Home, Google Nest, WiZ Smart Lights, PS4 & PS4 Pro are affected
- Netduma-FraserNetDuma PartnerCould you double check if you have the old router handling VLAN and the XR behind it whether you get the same issues? Prior to this though disable QoS completely from the Anti-Bufferbloat option 3 line option menu and see if that helps.
