usermac's avatar
usermac
Luminary
Jan 02, 2019
QOS Discord high priority traffic
Has Discord been added to the DUMAOS Classified Games list because now when I lauch Discord app the HIGH PRIORTY TRAFFIC DETTECTED  light is on. What happerens if I want to play battlefiled V and use discord at the same time does this mean it is priortizing both now ?
  • Hi Mac - it hasn't been added, no. Are you using Discord on your PC? Or have you added any manual rules to Traffic Prioritization?
    • usermac's avatar
      usermac
      Luminary
      I am useing Discord on a PC and no manual rules have been added Traffic Prioritization. As soon as I launch Discord it triggors Traffic Prioritization light.
      • usermac's avatar
        usermac
        Luminary
        My device is a computer but for some reason I have it set as a console/xbox. If I change it back to computer then the discord and the priorty light disapears. Only problem is when I have my pc set as device computer dumaos does not deteact any traffic at all. And the geo filter does not do its thing either.
