belykoral
Dec 15, 2021Follower
Question about Nighthawk gaming router
Hey guys, I have a question and wasn’t sure who to ask. Basically I just moved and I’m unable to hardwire my Xbox . I’m staying in a basement and the router is on the first floor. After testing, t...
Dec 15, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk Gaming Router products:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-routers
Basically I just moved and I’m unable to hardwire my Xbox . I’m staying in a basement and the router is on the first floor. After testing, the connection is supposed to be good but I experience lag quite often when gaming. I was considering buying the Nighthawk pro for gaming to help combat this. What I was wondering was
-is this a good method to help with lag -I’m only one floor down directly beneath the router/modem, would the distance be a problem since I can’t hardwire
Thank you.
