belykoral
Dec 15, 2021Follower
Question about Nighthawk gaming router
Hey guys, I have a question and wasn’t sure who to ask. Basically I just moved and I’m unable to hardwire my Xbox . I’m staying in a basement and the router is on the first floor. After testing, t...
Netduma-Fraser
Dec 16, 2021NetDuma Partner
I would say so yes, QoS will help to eliminate local congestion and the Geo-Filter will help to get you closer servers. The WiFi should be strong enough if you're right under it
