atangvels
Oct 03, 2022Follower
Question about Nighthawk gaming router
Hey guys, I have a question and wasn’t sure who to ask. Basically I just moved and I’m unable to hardwire my Xbox . I’m staying in a basement and the router is on the first floor. After testing, t...
michaelkenward
Oct 03, 2022Guru - Experienced User
atangvels wrote:
I was considering buying the Nighthawk pro for gaming to help combat this. What I was wondering was
-is this a good method to help with lag -I’m only one floor down directly beneath the router/modem, would the distance be a problem since I can’t hardwire
You could try asking over in the place where they talk about these routers:
Nighthawk Pro Gaming Routers - NETGEAR Communities
Be aware that people turn up here with problems. Satisfied customers rarely need to drop by.
Have you considered Powerline Ethernet?
