atangvels
Oct 03, 2022Follower
Question about Nighthawk gaming router
Hey guys, I have a question and wasn’t sure who to ask. Basically I just moved and I’m unable to hardwire my Xbox . I’m staying in a basement and the router is on the first floor. After testing, t...
Netduma-Liam
Oct 03, 2022NetDuma Partner
Great suggestion above!
From a DumaOS perspective, if you've got a solid connection to the router, be it by Wi-Fi, Powerline or Wired, and you're still experiencing lag, DumaOS can certainly help with this! Our QoS solution can prioritise your important traffic over everything else in the network, ensuring it's not held up behind anything else that's going on on the network.
- michaelkenwardOct 03, 2022Guru - Experienced User
An important question that I should have thrown in early on, how fast is the Internet connection that atangvels has?
Might also be worth knowing how many people use it.
Everything tracks back to that, The best hardware in the planet won't get very far with a crappy Internet connection.
I would diagnose what causes that "lag ".
