ranvealiu
Feb 15, 2023Follower
Question about Nighthawk gaming router
Hey guys, I have a question and wasn’t sure who to ask. Basically I just moved and I’m unable to hardwire my Xbox . I’m staying in a basement and the router is on the first floor. After testing, t...
Netduma-Fraser
Feb 16, 2023NetDuma Partner
It really depends why you're getting that lag, if it's due to using WiFi then it may not necessarily make a difference. If it's because lots of other devices are using the internet at the same time, downloading, streaming etc and or you're connecting to far away servers then yes the router would definitely help you.
