pinurmato
Feb 12, 2023Follower
Question about Nighthawk xr500
I bought my router a week ago and found out that once every 24 hours, it will lose connection for like 30 seconds and then come back up. I'm just wondering if there is a way to fix this? Is it some...
Feb 12, 2023Guru - Experienced User
What firmware is on it?
What modem/gateway is it connected to?
You might also have better luck in the proper forum (pro gaming forum) versus the standard forum.
