bloodbucket
Sep 20, 2019Aspirant
questions about XR500
so i want to buy the XR500 pro gaming and i have a few questions like will this router work in my country (iran) and also do i have to pay a monthly bill or something? i dont have a master card or paypal so i'm not gonna be able to use it if i have to pay bills
- Netduma_AlexNetDuma Partner
The XR500 works with your existing broadband connection. There's no reccuring fee once you've bought the product, just whatever your current broadband provider is charging.
- bloodbucketAspirant
so i just have to buy it and plug it in and it will work.
Be aware of Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATCouple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem.
