Tendrop's avatar
Tendrop
R-App is not loaded yet, please try again in a minute.
Gents - After installing the recommended firmware I'm getting the "This R-App is not loaded yet, please try again in a minute".  I've rebooted routed a couple times but it still happens.
Thanks for your help
  • get use to it. , lol if you got the 700 they will tell you to upgrade to  beta fw , but that wont fix the laggy dashboard and r-apps from not loading and crashing. lol you have to be logged in to get to dashboard online, maybe the cloud server's sh#$. who know's, apparently not NG. lol
    • Tendrop's avatar
      Tendrop
      Thanks for replying.  this is after I upgraded to the beta FW.   You're right very bugging and laggy setup overall.  Disappointed in this router.  Its still under warranty but my 90 days are up for the online support.
      If its not the LANs to my desktop and xbox disconnecting it's something else with this setup.  I may have to RMA or get money back.
    • mxa's avatar
      mxa
      Tutor
      My advice is to run away from this router asap, I have not had it run properly on any firmware using any configuration. Netgear is clueless and has absolutely no regard for its customers paying top dollar for a "premium" product.
      • Tendrop's avatar
        Tendrop
        Its quite sad.  I have RMA'd this router as of today.  Now you have me nervous they are all FUBAR.  I am sorry to hear you are having trouble with yours.  Did you RMA already?
  • FURRYe38's avatar
    Has anyone asked a forum moderator for the beta? The beta helps with the apps and UI.
    • Tendrop's avatar
      Tendrop
      Thanks Furry - Yes I installed the Beta FW on Saturday.  Started getting the R-Apps error message thereafter.  I need to reboot to remove the error but it comes back after a little while.  The beta FW was suggested by a Guide because of my original Post regarding the LAN disconnect issue having every other day or so.  The R-Apps madness was not as frequent on the other FW but it would show up now and then.  Just a head scratcher all around for a $500 router.   BTW, I've never seen the fans spin on this thing either so maybe it's a lemon.  I hope other people are having better luck with it.  When it works it does its job.  Mine has been high maintenance since purchase in March.
      • FURRYe38's avatar
        Post your experiences with the beta over on the beta forum so NG keeps on this.
        Was a factory reset and setup from scratch performed after loading the beta FW?
        What browser are you using? Does FF or Opera exhibit the same thing?
  • you can try the beta but it might have made it worse for me, not better at all!
  • FURRYe38's avatar
    Might ask NG for a RMA or take the xr700 back.
    • Netduma-Fraser's avatar
      Netduma-Fraser
      NetDuma Partner
      Sorry to hear you needed an RMA, hopefully the replacement will work better for you. Definitely give your feedback in the beta forum so they can work on why that is happening. What specific pages did you see the message appearing on or was it the interface as a whole?
