Mrpenguinz
Mar 28, 2021Aspirant
R-app not loading.
I've been trying to fix this problem for little over a year now. I usaully get annoyed after trying what's recommended and forget about it. My issue is since i've bought this router i've had trouble with the R-app not loading. Geo filter, QoS, Device Manager, netowrk monitor, hybrid vpn all will not load. Does anyone have any advice or fix for this in 2021? Router i'm using Is Nighthawk pro gaming router XR700.
you might have better luck on the forum for your device.
- Netduma-LiamNetDuma Partner
Sorry to hear that!
What firmware are you currently running on the XR?
- MrpenguinzAspirant
I'm using Firmware Version XR700 V1.0.1.38.
- Netduma-FraserNetDuma PartnerGo to the System Information page on the router and in the Rapp panel options change the number of retries to 5. Then reboot the router from the interface and see if it is better then.
