Mykro-PC
Jan 26, 2021Tutor
R-Apps
I love this router, don't get me wrong, I love Netgear products. I have been a faithful user and product promoter for ALL work I do residential and commercial work, pull wir...
Mykro-PC
Jan 26, 2021Tutor
All the pictures say is R Apps not loading try later on every r app but the main dashboard
- Netduma-LiamJan 27, 2021NetDuma Partner
I'd suggest you upgrade to the latest firmware:
https://www.netgear.com/support/product/XR500#Firmware%20Version%202.3.2.66
Please also perform a factory reset after the upgrade to ensure you're starting from a clean slate and see if the issue persists!
- Mykro-PCJan 27, 2021TutorThat would be cool if I had the xr500 but since I have the xr700 I think I will pass, but tyvm
- Netduma-FraserJan 27, 2021NetDuma PartnerI think Liam meant to link this instead: https://kb.netgear.com/000062838/XR700-Firmware-Version-1-0-1-38
Alternatively you could always try the beta firmware as well: https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/XR700-DumaOS-3-0-Beta-Firmware/td-p/2019958/jump-to/first-unread-message
