seryms's avatar
seryms
R7800 / AC2600 antenna replacement
One of the four antennas just broke and the wire got torn.  My router is R7800 / AC2600 Nighthawk X4S.  Where can I order a replacement?  I have been trying Netgear's (800) number but I cannot even talk to somebody to place an order because my warranty ran out.  Thank you in advance.
  • plemans's avatar
    Netgear doesn't sell replacment antennas but you can find many on amazon/ebay. Looks to be a standard rp-sma connector.
  • FURRYe38's avatar
    Please post about this here for your model router:
    https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk
    Good Luck.
  • I replaced my antennae’s with two 9db and one 5db antenna on my r7000. Worked good
