Check456's avatar
Check456
Re: DumaOS not loaded yet! XR700 (no 2.4 or 5ghz wifi either)
The same thing happened to me and I have found a solution that has worked for me so I am sharing this with the community.
I upgraded to the duma os 3.0 firmware for xr700 but it seemed buggy and I ended up with the dreaded '' Duma OS is loading wait 4 minutes.....''
I waited days to no avail.
I then managed to gain access via 192.168.1.1/adv_index.htm
I then downloaded a previous firmware XR700-V1.0.1.50.img
and uploaded this via the update section.
It fixed my issue and was able to log in properly.
The firmware which is the latest for my router was XR700-V1.0.1.50-0626.img
and was the culprit I believe causing these problems.
I have set up now on the older firmware (XR700-V1.0.1.50.img) which seems more stable and will wait for a patch to come out for it in the future before I decide to update it again.
I'm relieved because I actually thought my xr700 was bricked and after paying so much money for it.
Good luck folks and hope this helps you all. Any questions get in touch.
  • The same thing happened to me and I have found a solution that has worked for me so I am sharing this with the community.
  • FURRYe38's avatar
    What seemed buggy? Would need more details
    Did you install NetDuma's beta FW for the XR700?
    https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/NOTICE-NETDUMA-Beta-Firmware-for-the-NETGEAR-XR700-Router/td-p/2325278/jump-to/first-unread-message
    I have this loaded on one of my XR700s.
    Also the XR700 is EoL:
    https://community.netgear.com/t5/Nighthawk-Wi-Fi-5-AC-Routers/Top-NETGEAR-FAQs-Support-and-End-of-Service/m-p/2247940/highlight/true#M219659
    So probably won't be seeing any FW updates from NG. You might find 3rd party FW support if you want to keep the XR700 going.
  • FURRYe38's avatar
    Any progress on this?
