Gimli's avatar
Gimli
Tutor
May 13, 2018
Red led
Hello everyone!!!!!
I live in Brazil and my router arrived, I connected my pc in it, but when connecting a second device, in the case of my receiver, the led of the router turns red, in case the light of the lan that the receiver is connected, is this normal?
Thank you
  • It means you're using an ethernet cable that's limited to 100mbps or the device itself is limited to that speed
    • Gimli's avatar
      Gimli
      Tutor
      Are there any problems with leaving the device connected to the router?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        No problems, as I say just means device won't be able to reach over 100mbps.
