seroo's avatar
seroo
reduce Latency on a Three: 5G BB Unlimited hub with nighthawk
i know gaming on a 5g router increase latency/ping, i was wondering if anyone knows if this can be reduced by a gaming router?
  • A router cannot reduce the ping caused by the method of connection i.e. if the inherent connection is unstable you'll always still be subject to that instability regardless of the router.
  • plemans's avatar
    Gaming doesn't use that much bandwidth. A decent moca adapter or powerline adapter can help keep latency lower. (hardwired is always better)
  • FURRYe38's avatar
    Also be sure that the higher ping and latency isn't coming from the ISP side.
    Run a a test with a wired PC connected directly to the ISP modem or ONT using Pingplotter app.
