Sp4's avatar
Sp4
Guide
Mar 31, 2020
Router Config Compatibility
I am upgrading from a R8000 to a XR500. Is the config file for the R8000 able to be applied to my new XR500?
  • No you shouldn't transfer config files to different routers, they both use completely different software so would not be advisable.
    • Sp4's avatar
      Sp4
      Guide
      Thank you for the quick response!
