qasim9
Aug 02, 2018Aspirant
rx500 and alcatel G-240w-b
أنا من المملكة العربية السعودية .. لدي xr500 نوع من ألياف الاتصالات الكاتيل G-240w-b نوع الاتصال جسر و دعم شبكة محلية ظاهرية لدي مشكلة في توصيله ps4 اتصال pppoe لدي اسم المستخدم وكلمة المرور isp ولكن...
Netduma-Fraser
Aug 02, 2018NetDuma Partner
You wont get NAT Type 1, that just means connected to the modem. NAT Type 2 is also open, just means connected behind a router. Do you have internet through the PS4?
- qasim9Aug 02, 2018Aspirant
Yes but I'm having a high ping ,, I want the best way with modem alcatel fiber, do you by bridge, pppoe?- Netduma-FraserAug 02, 2018NetDuma PartnerOkay you need to start with the exact issue you're having and more details. What games are you playing? Are you using QoS or the Geo-Filter? Do you know if you have PPPoE?
yes < fortnite
