qasim9
Aug 02, 2018Aspirant
rx500 and alcatel G-240w-b
أنا من المملكة العربية السعودية .. لدي xr500 نوع من ألياف الاتصالات الكاتيل G-240w-b نوع الاتصال جسر و دعم شبكة محلية ظاهرية لدي مشكلة في توصيله ps4 اتصال pppoe لدي اسم المستخدم وكلمة المرور isp ولكن...
qasim9
Yes but I'm having a high ping ,, I want the best way with modem alcatel fiber, do you by bridge, pppoe?
Netduma-Fraser
Aug 02, 2018NetDuma Partner
Okay you need to start with the exact issue you're having and more details. What games are you playing? Are you using QoS or the Geo-Filter? Do you know if you have PPPoE?
- qasim9Aug 02, 2018Aspirant
yes < fortnite
I sent you a message .. ؟- Netduma-FraserAug 02, 2018NetDuma PartnerYou will have a higher ping as you will most likely be connecting to EU region as its the closest to you. Images did not show up in PM. Post here.
