JonnyC777
Apr 18, 2025Aspirant
Sky Max getting installed, would like to use my XR500 router instead of supplied Sky Router
Hello
We are switching from Virgin to Sky for our broadband provider.
Currently we use our Virgin Hub 5 in modem mode with our XR500 as our router.
Sky hub has no modem mode and we would like to avoid double nat etc.
Sky forum bunch recommended to ask here if its possible with the XR500 and how to set it up if so.
Any help will be much appreciated, I have very very basic knowledge in this area!!!
Thanks for looking
Jonny
You'll need to get with the ISP and have them help you with installing any external router like the XR router.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
