Pblou916
May 25, 2020Aspirant
Slow Speeds via Wifi and hardline with the XR500
I just in stalled the new Modem and Router. Once i did so my speeds droped from 900+mbs to under a 100mbs. If i bypass t he router i get the 900+mbs. I have tried disableing QOS and other tricks that i have read up on via the internet but to no luck. If i can't get this issue sloved soon i will be retuning the router for another option.
CM1000 paired with the XR500.
My ISP speeds are 1000/50.
The modem and router are using the latest firmware.
Have you tried replacing the cable?
or manually setting the upload/download speed settings for the router? maybe its using a lower setting
https://kb.netgear.com/000053112/How-do-I-set-up-QoS-on-my-Nighthawk-Pro-Gaming-Router
- Pblou916AspirantI have a few different variations from I have read to see if maybe that was issue but no luck.
These are the combos I tried.
1. 95/50
2. 95/95
3. 97/97
4. 85/50- plemansGuru - Experienced User
did you try changing cables?
And why are you manually setting a low speed than what you're getting?
manually set your isp speeds for the gigabit you subscribe to and the modem puts out. (according to your prior statements)
