joblack85's avatar
joblack85
slow speeds xr300
hello guys, not really a tech guy so I'm lost on what I should do to get my speed to where they need to be.  I'm on comacst 1000mbps gigabit and I have a xr300. my ps4 is only giving me 200mbps lan and wireless less then 40mbps. i have a 2 story home  and nothing wired upstairs so its even slower. any step by step tips
  • plemans's avatar
    What modem do you have?
    What speeds do you get directly off modem? (key as its pointless to troubleshoot a router if the modem doesn't get full speed)
    What speeds do you get off a gigabit laptop/pc connected to the router?
  • What do you get from a wired PC? Have you set your bandwidth speeds on the router interface?
