DOGGAVELI's avatar
Feb 22, 2019
SX10 Setup Help
Hi Everyone,
                     I recently got the Sx10 gaming switch my home setup is ISP modem to XR700 to Sx10 I have DMZ the switch in the Xr700.
When I game though I get lag/glitchies occsionally with the Switch my internet is ADSL 2 15mbs download and 1mb upload.
I play online xbox live games BO4, WW2, Pubg, Mhalo MCC & Halo 5.
Was hoping if other people encounted this issue and any setup tips to overcome it. I'm also using the 10gb switch plug in the XR700 into the Switch all setup correctly. Appreciate any help/advice and setup options/tips.
Kind Regards,
Dogga
  • The switch I believe has it's own QoS/traffic management. I would suggest you disable it as it may be interfering with the XR700 QoS.
    • DOGGAVELI's avatar
      DOGGAVELI
      Star
      Hi Fraser,
                     I've actually been doing that but it still occurs so I have stopped using the switch at the moment and just using the XR700.
      Brado has had the same issue as well, so I thought I'd post in here and see if anybody else had similar issues.
