Kierok3's avatar
Kierok3
Guide
Apr 06, 2019
Thinking of returning XR500
I have two ps4s wired connection to my new XR 500 router. I'm trying to match the two systems into the same crucible game in destiny 2 but the geo filter doesn't seem to have any effect on this. I'm looking for some guidance for the two hosts to find each other in matchmaking.
  • Hello, I'll answer in this topic as your other one is about the same thing, no need to make multiple topics.
    If I'm correct you want to just find each other in the same game instead of going in as a team from the lobby? If so then I don't think this would be possible or it would be very hard to do so. To team up both devices should be added to the Geo-Filter just in case and then use the Destiny profile to set up this filter.
    • Kierok3's avatar
      Kierok3
      Guide
      Hi there!
      Thanks for the response. It is possible, I have been in lobbies with other people doing it. I think it has something to do with white listing everyone from both fireteams but I'm not sure what I need to choose for my geo filtering home location. I was hoping to find someone that knew this on the forums.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        The only way that I could possibly think would be to place your location in the ocean at the same point with strict mode enabled and ping assist at 0. If you're only doing it with two people then I doubt that this would work.
