Alewi
Nov 10, 2019Apprentice
Traffic prioritization help!
Hi nighthawkers,
I want to add my ps4 manually to traffic prioritization. The steps are add device, chose a game! Here is the issue... the game I want is pro evolution soccer 2020, which is not listed. So I chose advanced, source port the default (1_65535) destintaion port... I have no idea, so I also put (1-65535), protocol (udp&tcp). It worked and I got the traffic indicator red light. The problem is that the anti bufferbloat stop working! I can't control the bandwidth limit any more! What can I do to make the high traffic priority detection works as soon as I run my ps4, without waiting to run a game? Thanks in advance for your suggestions.
- Netduma_AlexNetDuma Partner
Once all the traffic from a device is added to High Priority traffic, you will no longer be able to limit it's bandwidth as it is all being prioritized.
What you should do is search online for "PES 2020 port forwarding" and put the ports that are listed into the Traffic Prioritization menu.
- AlewiApprenticeHi Alex,
I will try it and tell you what gonna happen. Another quistion. Is there any way where I can get the ps4 directly prioritized when I turn it on and before i start a game?- Netduma_AlexNetDuma Partner
I personally would recommend just using the DumaOS Classified Games option
