Wyzfar's avatar
Wyzfar
traffic prioritization
im prioritizing CoD: Bo4 for PS4 in the advanced tab using port 3074 udp is the source port and destination port 3074 for start and end ?
    • Wyzfar's avatar
      Wyzfar
      Ok so I don’t have to use the source range 1:65535 ? And would there be any benefit to prioritizing the ps4 ports as well
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        DumaOS Classified Games prioritizes the console automatically so there should be no need to manually add ports for any game on a console. No you don't have to, it defaults to that range to prevent people making misconfigurations. Yes there would be benefit as long as you don't prioritize downloads.
