boomerx01's avatar
boomerx01
TWO XR500 for whole house coverage?
I have an XR500 Configured with QoS, etc. - but I have a 3,000sq Ft two story house and need more coverage.  I have a hard wired connection available downstairs, can I run ANOTHER XR500 in AP mode some how to extend the network?
Or should I use a EX7000, something like that, that will take a hard wired line to extend the WiFi network?  Thanks!  #xr500
  • You could do either really, in my opinion unless you may need another XR500 in the future and will make use of the DumaOS features then it's a little overkill to get another just to run in AP mode when those features won't be used.
  • FURRYe38's avatar
    I ran a EX7700 with my XR450 in a 5000sq ft home. Worked well.
    • boomerx01's avatar
      boomerx01
      Were you using a wired backhaul?  It seems certain models don't support this function?
      • FURRYe38's avatar
        No, EX don't support wired backhaul.
