usermac's avatar
usermac
Luminary
Aug 03, 2018
Unable to install because some filters are overlapping.
When you add a device the geo filter ask for the game. What I dont under stand is if I add the same device one that is set up for PUBG and then try to add the same device to work with Call Of Duty for example it warns me "Unable to install because some filters are overlapping." Do I really have to delete the device when I change games or can I some how have one device added and change the game profile to match the game being played ?
  • Good catch. The CoD profile uses most UDP ports, so it's rule overlaps with PUBG when you add that too. So I recommend you just use the CoD profile for both games. It will have no impact on your experience - you will be able to see all the PUBG servers etc and block accordingly.
    Could you try this please.
    • usermac's avatar
      usermac
      Luminary
      I have done what you said but something does not seem right I am also getting really high ping host I will post screen shot.
    • usermac's avatar
      usermac
      Luminary
      When I choose the call of duty profile and then run pubg I get wrong icons showing up all over the place but does not seem to show correct server info as it says I am connected to a peer rather than amazonaws. Using the call of duty profile does not work with pubg not for me that is. Any chance I can get help setting this router up vie team viewer please
      • Netduma_Jack's avatar
        Netduma_Jack
        NetDuma Partner
        Hi - The CoD setting must be picking up a bunch of other traffic on your PC. Fraser, our lead tester, will be back online tomorrow and he will be able to recommend the best Geo-Filter setup for you.
