Xrv
Sep 30, 2020Guide
Unable to install Plex V1.0.1.34
I am not able to install Plex server after updating to the latest firmware V1.0.1.34. I did a factory reset after installing the firmware and I try two different USB drives without any success.
- Netduma-FraserNetDuma PartnerThe timezone may be inaccurate on the router, update the timezone to your region and then try to update plex again.
- XrvGuideI already double checkt and the time zone it's correct. I had similar problem before when I used the DNS addres from vpn provider but that was with a previous firmware. Any new suggestions?
- Netduma-FraserNetDuma PartnerSo you're not doing that again this time? How is the XR connected to your setup is it behind a modem or a modem/router?
- andmas81Guide
Me out
Hi, I have the same problem, did you get a fix from netgear it's starting to stress me out
